My 2016 Hellcat build and update post.
place has awesome breakfast sandwiches!!
Those types of places always have the best food.
You ever go to Helen's Sausage House in Smyrna DE? Some of the best breakfast food around.
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #243
I haven't been yet but ill check it out one day.
New factory Hellcat pump. More than enough PSI. 68 psi cruising hot, 50 psi hot idle. haven't gone WOT yet but I've seen 72psi at 4500rpm hot.
About the same as I’m seeing, I’m using a stock hellcat pump too.
What oil weight you using? What kind of oil temps you seeing at what ambient?
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #246
20w-50 as per the Engine builder recommendations. Oil temps are between 190-212, I was pretty hard on it yesterday all while staying under 5500 rpm and got the oil temp up to about 220. yesterday was 85-88 and humid here.
Im seeing about the same, I’m running 5W50 but next oil change going to 15W50. I’ve seen 225 max oil temps in 80-85 ambient even after repeated 1/4 runs. I run E85 and after running the oil for 5-600 mostly hard miles see a 5 psi drop in oil pressures idle to WOT, change to fresh oil and pressure is back. Oil tests do not show a viscosity issue or a fuel contamination issue. I just don’t know why this happens. Is it normal? I’ve heard such is running ethanol? The Mobil 1 15W50 I’m going to try has the same 100C viscosity as Valvoline VR 20W50 but a much thinner cold pour numbers then the VR. But check this out, there’s 2 types of Mobil 1 15W50 synthetic oils, the racing version has more zinc and not as cat friendly and I’m still running through cats so I will be trying the black label first, has about the same goodies as VR.
6D3198EA-98CA-4678-AF23-21F7A96D1A8E.jpeg FED7021B-C8ED-4AF1-85D9-F13CFEEEBFB0.jpeg
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #248
I'm running the VR1 20w-50 in mine. that's what ill stay with on this engine. It's and awesome oil. plus I end up changing my oil so often, Synthetic isn't needed. normally get 100-150 miles between oil changes.
You’re catless though right?
I go about 1000 miles between changes
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #250
yup catless, with E85 the cats really aren't doing anything anyway.
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #251
<iframe width="473" height="841" src="
" title="July 24, 2023" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
I just keep them for just in case compliance. At 1100 wheel anything more they will need to go. I do have a set of catless mids for that day.
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #253
I keep my cats because of noise.
I'm still running Mobil 1 0W40 in mine. I've not seen any drop in oil pressure over 3,000 miles or so oci. Mine shows 43ish idle and 73ish wot. My engine is stock though.
BTW, that thing sounds AWESOME!!
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #256
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #257
" title="Hellcat remote start, cold start. #1320tunes @Smurfed_cat IG" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Like Coco Robicheaux playing the juke joint! Sounds awesome, most modern Hemis can't sound like that without pulling a coil pack.
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #259
Haha nope! remote started, no codes! Just a build that has been in the works for a while with a lot of great minds involved helping me. I have not heard many other Hemis that sound like this.
RGPIII
RGPIII
Bridgeville
DE
Thread Starter #260
100 mile break in done! Not one spec of metal in the filter or oil! It’s go time! 😈😈
