before spacers and after spacers pics.
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
gates belt 100594
2.85 upper
incognito sleeve
stock tensioner
Failing to see the significance? Why do you need to run spacers?
rookerrobert
rookerrobert
Ridgeland
SC
because I wanted to that all the reason I need....that and the belt is a little tighter also and with the blanket it also lower my temp. on i/c
Apologies, I thought you meant spacers on the pulley and sleeve. LOL, I run the FI spacers as well, they are awesome.
Looks like it didn't move
rookerrobert
rookerrobert
Ridgeland
SC
thats ok I guess it's my fault anyway....you know how we assume.And yes sir your right my i/c temp on a 90degree day stay around 90-96 unless I drive it hard and then they'll climb but come down soon after
rookerrobert
rookerrobert
Ridgeland
SC
very darn little put the spacers are only 10mm anyway.But every little bit helps
I did idler pulleys (slightly bigger) and spacers so mine way off a bunch so I changed the belt
rookerrobert
rookerrobert
Ridgeland
SC
thats what I was going to also but it dont slip and and it is close might be a little tight but not by much
