What are you guys using for paint stripper?
I’ve got cast iron parts from my other car that require a repaint and instead of sand blasting them I am considering a paint stripper. Can anyone recommend a good product? Thanks all.
I remember using something called stripeeze.....most are gel types...and work pretty much the same...it can be a messy job
I’m using this crap, Klean Strip, certainly taking its time. About 30-35 yrs ago I picked up some aircraft stripper that you could watch the paint bubbling up, worked like a charm. From what I understand some ingredient has been eliminated due to safety concerns.
45-70govt
Ghetto
I use this stuff. Works great! The trick is to get your parts tightly covered in plastic wrap ASAP after application to keep the chemicals from evaporating too fast. Let it sit 15-20 minutes then paint just wipes away. It is also great for finding small unknown holes in your gloves as it will burn like hell on your skin.
45-70, thanks for the plastic wrap tip. I’ll try that. Can’t see how the stripper wouldn’t tear through plastic wrap in seconds!
I mainly use those grinder discs that look somewhat like a black sponge.
Otherwise, NTerpinal works well, even on powder coat.
I’m thinking I’m just going to sandblast the remaining parts. I stripped the water pump just because I want to be careful about sandblasting near bearings.
I acquired an old cement mixer. removed the pieces inside, poured in a bucket of 1/2" stone, throw in the parts, and let it run a few hours. Whatever doesn't come off, doesn't need to.
Wash with acid metal prep, and the new paint will stick longer than you will live!
