Here is what I have on both cars with 305's, except this paint config is apparently no longer available in 10.5. The pockets were black and I repainted them to gray.
https://factoryreproductions.com/pr...lcat-replica-wheels-gloss-black-machine-face/
Some of the other "slingshot" wheels are available in 10.5. I am very happy with them. You can always have a wheel repair shop refinish the wheels to match your wheels. Here is the 10.5" FR next to the OEM.
I still have my stock Brass Monkeys and tires boxed up somewhere...from my HC...(not sure why)...
Why? Because the wheels don't go bad.
Give the tires to someone who doesn't know about date codes.
I was thinkin the same thing bout the tires...nobody I know checks the dates....
Being the springs were in and out that could have changed it. Going minus 1 (if 5 tab go to 4) on the right side may get you close. I aim for -.25 camber, toe in around .10
Yesterday I put a 4mm in the left side (shorter arm length) from a 6mm that was in it. Thinking I want the slight negative camber equal on each side. Only moved the top arm, loosened the front arm in case there may have been about a hair of any adjustment play. Did not bother to do any measurements. Then drove it. Well at 50 degrees IDK. It basically scared me, I’ll admit a couple of times. SOB has some incredible power and at 50 degrees even the big meats are interesting to control. I think it is “tweaked” good enough.:ROFLMAO: Dropping it down at low speed, a few Track Mode wicked shifts with plenty of subsequent wheel spin, and a couple medium high speed “pedaled” pulls all seem good. That is enough until we can drive it 120 miles to the north of here prepped for some serious shit on a warmer day with even better rubber. She is a good street hot rod until then, and is ready to rumble as necessary.
Wizza
Stafford
VA
2015 Dodge Charger Hellcat
Went on a fantastic 4 hr cruise thru North Western VA today
You really should be able to beat the predicted travel time by far more than four minutes.
Unless, of course, you're in an EV.
So many things do change as you know when you move them. You went to about 0 based on -.50 you were at. Cold roads are bad no matter where the setting are at
