Do the right front in the first quarter, the right rear in the second quarter, and so on.
In one year they're all done and it's time to start over.
Fuck that...maybe I've applied the brakes 100 times each car...fluids fine...I should know better than to listen to melon heads that think they have to change their oil every 15 minutes..:rolleyes::rolleyes::rolleyes:
At LEAST every two years, climate dependent.
Here in Colorado, it's dry, if you're in humid areas, either every year, or don't run it at all, unless you're specifically tracking your car, and then you're going to be refreshing every session anyway.
DOT4 is much more hydrophilic than DOT3.
I run it because I occasionally track it, but more so because I do so much brake bedding, to the point of fade.
This topic made me think...for the past 24 years..I have driven Ram 1500's...(a new one every 3 years) I log 120,000 plus miles on each one...I have never had a brake fluid flush service on any of them...they are work trucks...(severe duty)...never had an issue...now my cars are in a controlled environment 50% humidity...65 degree temp all year long...I have never had a brake flush service on any of them....again never a problem....yet my bikes have a complete dealer service EVERY 2 yrs....(with the brake fluid flush)....what does all this mean:unsure:....I have no idea...I'm not that smart..:rolleyes:
Keeping them for the first 3 years, you're not seeing the affects of moisture in the lines/calipers, and frankly what you're describing sounds fine.
If you were at the end of 20years, which people do ALL of the time, you would see rust inside the caliper pistons, and notably degraded braking because all of the water content in your fluid boils quickly compared to brake fluid.
BUT, if you're driving a truck, like a truck, in the city, no hills, no heat in the brakes, no weight, no stress, you could probably run peanut butter and not really know the difference.
If you took that 20year old truck and stressed the brakes, you'd find out in a big hurry about water contaminated fluid, or come out here and come down I-70 from the Continental Divide into Denver, and boil, and then fade them...
...happens all of the time, occasionally even makes the local news... ...occasionally...
Absolutely fell in love with this car again. Still won’t race it. Maxed out Pratio… 😭 gonna up it and see how much boost she’s really making.
That's good to know.
We once put water in the master cylinder to be able to make it off a trail and back home. Water, since nobody wanted to waste their beer. Well, those brakes only lasted about 20 miles.
Had we only known that peanut butter would work...Not that we had any, but still.
I heard about guys using recycled beer in the radiator....
We've done that. And used oil out of sardine cans in the crankcase.
Sometimes, after a rollover, you do what you gotta do to get going again.
That's exactly why I always have a case of beer and a case of canned sardines in the trunk at all times! :ROFLMAO:
Nobody does except @BULL :unsure:
Drive that garage queen once in awhile, way too clean
You should see that same wheelwell now after HEAVY bedding and braking... :(
Well, where are the pics:LOL:
DaveB
Penhold
As per @MMissile, I finally drove the HC today. Most years I have the insurance back on by mid-April…not this year. Was a good feeling getting behind the wheel again. Did about 60 miles….came home and logged about the same seat time on the mower. Lol.
Of my car?
Dirty?
Shirley you jest?!
I do and don't call me shirley
Of my car?
Dirty?
Shirley you jest?!
I just knew sooner or later....there was gonna be something I really liked about you...:giggle::giggle::giggle:;)
Latest Forum Posts
