Live action from FUMANCHU182.
Man, she looks pretty used-up :oops:
Thread Starter #1,802
Thread Starter #1,804
old diff bolts and a pry bar, 32mm impact socket and ugga duggas. IMG_8909.jpeg
Dirty hoe, simple green and brake clean, high af after 71657589531__9F9D5E94-3863-4C5A-BEE4-2D91D1FDD5D9.jpeg
In the kit comes a setup plate, bolts sourced out of the fuck it bucket IMG_8931.jpeg
caution: do not use brake clean on the pinion flange, pressed rubber bushings you cannot replace, pinion was inspected, all bearings good, all machined surfaces good. IMG_8935.jpeg
Pinion gears are sharp, need to pull the ring gear but thats a tomorrow me problem, time to go get beer
Thats a hell of a beefy bearing arrangement there on that pinion assy!!!
Thread Starter #1,806
It is, pain the balls to clean. However they spin freely now, was having an issue where it was binding before cleaning, think there was a ton metal in there. There are no specs on ZF diffs so its going to be trial and error to get backlash correct. I have numbers from dusterhoff and will confirm on assembly. Need to pickup seals on Monday.
Okay now I see why there’s no aftermarket dang
This is some of the most beneficial info I have seen on the forum. Following this closely, great job @fumanchu182
Good to see you can disassemble the pinion and install it theoretically in any case. Thinking I should have kept my 3.70 as a spare
Thread Starter #1,810
The ring and pinion would be different
Right, but if a case went bad you could swap them into a new case if you crack one or whatever. I was under the impression (and thought I had heard) the pinion wasn’t removable
Thread Starter #1,812
I wouldn't even dare try to remove that pinion from the shaft. It is hard pressed on there and would be a hell of an effort. But yes you are correct, cases are swappable. I have my LLC being processed by ZF to see if I can get FSM and repair specs.
Great stuff! LMAO at the "fuckit bucket" quip. Yea, ZF seems totalitarian on control of parts and service data - pisses me off! Hopefully, they will wake up and realize with millions of Chargers and Challengers built, there will be a healthy aftermarket demand for diff and transmission parts for a long time.
Thread Starter #1,814
So I did find this documentation on the pinion flange removal and installation to repair the seal. This helps me with re-assembling that, however I didn't mark any orientation as I was cleaning out metal so that was more of a priority. I wonder if imbalance will occur. However if you install this into a billet housing there's no way to keep track of that so, by reasoning maybe its a herring???
this is for re-assembly
My mind boggles at this:
"If the pinion nut alignment index mark exceeds the pinion shaft alignment index mark the unit must be discarded. If the pinion nut alignment index mark falls short of the pinion shaft alignment index mark the unit will possibly generate an Noise, Vibration, or Harshness (NVH) concern."
Knowing this I would have just bought a billet case and said screw it with these housings. However I don't think this will be an issue, we shall see.
Thread Starter #1,815
Calling in the big dogs @Hatermkr do you have any torque values for the pinion flange nut?
Yea, I don't have a feel for this ZF design since I have never seen a big ass ball bearing pinion design like that until now - all US stuff I know of has tapered roller bearings as you know. I for one sure appreciate you sharing your journey into the unknown with us - I bet a lot of us are taking notes :sneaky:
Yeah wonder what the point of it being engineered that way is
so let me get this straight. They’re marked from the factory (maybe), and if you can’t see the mark on the pinion flange and the nut, you’re supposed to make your own index mark before disassembly to mimic factory “torque”. Is there no set torque spec for these??? Blows my mind too. I guess that’s how they get around telling you the torque specs? Then again they also tell you to index the driveshaft before you take it out I haven’t done that and I’m fine, maybe I get lucky but that doesn’t have anything to do with torque indication like this index mark would
Trackhawk, RS3, Golf R
Great freaking info thanx of posting!
oilburner
coboconk
there is no torque for the nut, you tighten the nut till you achieve bearing pre load. tighten in small amounts till achieved. do you have the spec for pre load cause I couldn`t find it anywhere but I had no reason to take my flange off when I did my wave track. brgs. felt smooth with no end play.
