this am i sent my oil change sample out to blackstone labs. 30$
DSRT Bath day!
Put my rear braces back on. What I found last year with the front one, there is a rubber piece that goes between the brace and rear and it started to come out. So I used some heat barrier tape and wrapped it around the brace to keep the rubber in place. Also had to notch it for the aluminum flash on the snout
Safety wired mine per the instructions. The pad still has moved towards the rear just a bit still.
@Mo-par!
Maybe investigate a vulcanized solution for the two posts above???
TorRedHellgato
New York
2020 Dodge Charger Hellcat
Washed and quick detailed. Then put away for the week since the weather report isnt looking good. Lol
Idoru99
Springfield
VA
2021 Challenger Redeye WB
Woke the cat from its winter hibernation.
Screen isn't working, I assume it's because I unhooked the battery to install the rear OBDII port in the trunk.
Sent from my SM-G975F using Tapatalk
Just had a glass of Cali 1975 Cab with mine, or was that the hooker I drank with. Mine is fine as the wine, both in the garage.
Nice color combo. I have the total reverse combo. Om bo.
How about a picture? You can hide your license plate.
I am attempting to get Rico la over here to take some pics with his fancy camera. My phone gives it no justice. Have the car on my Avatar, but need to new pics of the satin paint. The engine paint is a killer. Looks great, the whole car looks great. I do believe summer is here. No, not the gal, weather. Lower 90s and will shoot upster shortly. A/C has not turned off. Need to get this internal chiller installed. Last trip to the dealer this week,,,, F- em. Then the fun starts.
ordered some burn-out guard and started researching a killerchiller vs bloody heat exchanger. also, wondering best spot to get the intake spacers and s/c blanket?
Is burn out guard that spray on stuff?
I don't use anything because I get barely any rubber on my car.
Idoru99
Springfield
VA
Yes, it is.
Yes, it is.
Don't know why you would need it. I ran 2 events the other weekend and had maybe 5 pieces of rubber in my wheelwell and maybe 2 on my quarter panels.
After a lot of investigation. I think the visions and confusions have been determined, BUT. That was said during the stupid ice tanks came alone. Find your best product for the price. The blanket is a product called mineral wool. The amount used is $ 30 worth. I have used this product since the 70's. Spacers,, not a clue. Spray rubber with adhesive involved?? I wood snot.
