Two Tuned Redeyes
Thanks for the help guys.
Local guy just told me he didn't need them on either his NB or WB Charger. I ordered the Racestars (good price on closeouts) and I'll see. HHP has them for $85.
Now I'm looking for a sale on MT's! :)
You don't need the end links? I had seen if you jack the car up from the control arm some have done it but using the side jacking point they will not go on
The bwoody links are about $100 and way beefier then stock. Also like said the racestar lug nuts suck. I have foresters and they are lighter with no stupid lugs
Do the Racestars require special nuts? Summit didn't have any info.
Racestar sells a lug nut kit
Yes. You have to buy a "kit".
Not sure what you are saying. Hey, I'm old...
A friend of mine doesn't have them on his Charger and he has Weld beadlocks.
You said the local guy said you didn't them. Was he saying the endlinks?
Local guy just told me he didn't need them on either his NB or WB Charger. I ordered the Racestars (good price on closeouts) and I'll see. HHP has short links for $85.
So what was $85, endlinks? You want the bwoody ones. They fit the best and are beefier the HHP. Also if you ever put AAD arms on (highly recommended) the HHP will hit
Thanks for the info, always good to check. Just got off the phone with Summit, they said the Racestar 95's I ordered use the 60deg conical and he believes that is the same as OEM. He did not see a kit for these wheels. We'll see.... No hurry, the dragway won't be open for months!
not the same as oem
The skinnies that I put on once had a oblong washer with long shank lugnuts. They were a royal pita so they were replaced immediately.
Hopefully yours isn't like those.
The skinnies that I put on once had a oblong washer with long lugnuts. They were a royal pita so they were replaced immediately.
Same with me. I used them a couple of times and went with the forgestar
I went with VMS on the front. They match my new Weld beadlocks.
Just got off the phone with Racestar. The 95 wheels I ordered have a conical seat that work with OEM nuts. The 92 wheels, their most popular, require the kit. The only warning was that the c’bore might be small for some sockets. Again, I appreciate all the help to try to get it right the first time! :)
Good to know. Then get the gorilla lugs for it.
Have a photo of the obling washers handy?
