Hot Rod Drag Week 2025 is here!
I didn't forget about you guys but Day 0 & Day 1 were a hoot. That drive up around Baltimore was hot garbage and only got worse for the all-run cars.
Day 0 we went 9.979 @ 138.50 - sent her a little too hard. That was launching at 1850 and with the 2.65 pulley.
Day 1 was about 10* cooler so we had to do something about the fact it's MIR. We pulled the launch down to 1300 so it made 0 boost at the hit. Still cut a 1.51 60' and went 10.027 @ 138.6 lifting at the stripe.
That however has me sitting 1 after day 1 by .024...didn't expect that at all TBH.
Day 2 is Numidia. Grabbing bite then heading to the track.
Good luck!
gtsdude
Law Enforcement
Spring Valley
Watching the live stream for ya.
Are you foot braking? How are you launching?
F
We are using Launch Control and have been since drag week last year. Isn't that great for setting PB's but on this car it's been super consistent A-B passes almost every time.
Interesting, it doesn’t bog out on you in the middle of a pass at all and abandon it? I guess since you’re not actually racing the other person in drag week it doesn’t matter and you can sit there as long as you want to get it all set
F
The results from Day 2 haven't been posted as of this post.
Day 2 from Numidia saw the Diehl Brothers hit the wall at the top end which Essentially totaled the car and shifted the barrier 90* from the impact. Several other big power cars seemed to have issues as well but many improved on their times.
Historically numidia has been a slower track for me ET-wise. Dr. Dial-in calls it about .035 slower than MIR but the temperature was also cooler today. I knew I could put the power back Into it so I dialed up the LC to 1500 which usually hits with 6psi off the line.
The car decided all on its own to flash to 2200rpm and HOLD IT without pushing thru (first shocked face) then after it Launched with no spin (second shocked face) I decided to run it out the back to a 10.046 @ 140.3 - checked the log and it left on 10psi (third shocked face). Not the first time it's picked its own launch RPM but definitely the first it held over 2k without pushing thru. Also the first launch on 10psi. I dunno. It worked though so I'll take it.
F
You have about 5-7 seconds before it'll cut off the LC. If we both stage as you should...I stand on it immediately and it's never shut off yet unless the guy in the other lane screws me.
In the middle of a pass? It disables itself over 60mph anyway but by then you're well on your way. It doesn't show itself missing a beat in any log I've taken.
I’m most likely going to a 2 step but I most certainly need a redeye torque converter. Wish someone would create a trans brake for these already. All you have to do is activate the 1st and reverse solenoids in the transmission at the same time, which is all done via can bus messages.
If it senses any spin it usually kills the run
And you have a regular hellcat torque converter? That’s very interesting
