Everyone with 315 on the rear what is your psi?
Tape
Tape
Hell
2021 Redeye
Thread Starter #41
Discount Tire just called and said the tires were not in.:(
Tape
Tape
Hell
2021 Redeye
Thread Starter #42
DT called later this afternoon and told me the Pirelli P Zeros were in so I went and had them installed. The tires are pretty sticky, they pick up gravel and debris off the road but on the regular roads and highways nice and smooth. I don't think I'm going to get over 7000 miles on these tires. Installed them at 2807 miles.
Curious to see the tread pattern at 7807 mile.
PK wheels with Pirelli P Zero tires installed total weight 59.8lbs
Prange
no longer in Chicago
2021 Charger Scat Pack
#43
I see what you're after, now. Looking for a good non-DR for street use. I've been that route before myself. Thanks for sharing the detailed data.
That's exactly what I'll be looking for next spring.
Tape
Tape
Hell
2021 Redeye
Thread Starter #44
I installed the DIRS just so if something happens it will contain it to the rear end; hopefully
I also bought the one for the Borla exhaust but you can clearly see the regular brace would have work just as well.
for $500 it seems like good insurance whether or not people believe it helps or doesn’t.
22MoparMuscle
Chicago
2022 Challenger Hellcat
#45
What are the best 20 inch tires that fit the Challenger HC WB? That fit The stock rims that are 20x11 I think. I just need stickier tires for the street. Nitto or Mickey Thompson ?
Edit: I’m not gonna need tires for the drag strip.
#46
I had 20 x 11 aftermarket and ran mickey Thompson ET street SS for the most part (also 555Rs). They did ok on the high heat composition west texas asphalt but were not perfect. Usually ran 28 psi cold, if I remember correctly.
On the street I run them as low as possible cold to not trigger a TPS alarm upon first drive until they warm up usually 26-27 psi cold does it, that’s on 555R2’s and NTO5R’s as well
#48
Any way to turn off that warning light and chime with hp tuners?
#49
I believe you can do that, with AlfaOBD, as well. I know you can, on RAM.
2fast4u
Edwardsburg
#50
yes, AlfaOBD will turn off the tps alarms.
