Sign Up! To view all forums and unlock additional cool features
Do yourself a favor and get one of these. Remote mounted. Uses a -10 line from each valve cover and vents crankcase pressure at the top of the can thru the filter. There is no oil returning to the intake.
Do yourself a favor and get one of these. Remote mounted. Uses a -6 line from each valve cover and vents crankcase pressure at the top of the can thru the filter. There is no oil returning to the intake.
View attachment 73313View attachment 73314
Not sure on how a pulley would work but this is what they call clockable. The mounting bracket can be positioned 360 degrees around the can so it can be mounted in any direction to accommodate the direction the hoses need to go.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
