Battery: parasitic drain
45ma is not terrible but does seem high. First thought is a float charger, I keep one on all the time. They are capable of 750ma but my measurements show they supply about 5ma when charged, which is why I say 45ma sounds slightly high. A float charger would probably be a good band-aid.
I have analyzed parasitic losses several times in the past. Recently a friend with a 2010 or so Ram was pulling about 200ma. I left the meter on the battery and pulled fuses one-at-a-time until it went to zero. It was a dashboard circuit. Then I started pulling power wires of the devices on that circuit, when I pulled the radio, it dropped to zero.
Walland
23 Challenger Demon 170
Damn batteries don’t last nowadays!
Catless
Parkersburg
WV
2015 Hellcat Challenger
I have tested several modern vehicles and the normal parasitic draw after the bus goes to sleep is around 30 mA (0.030 A). All 3 of our Chrysler vehicles are 30 mA and my 2011 GMC truck is 25 mA.
Did I say haven't replaced a battery since I started using float chargers?
Maybe it is as you are saying, the old ones are better? Could be...
Sounds reasonable, and the reason why a float charger is so important on a vehicle that is not used every day.
Kubota batteries are supposedly very good. My early '10 M6040 is still on its original battery.
It does have a permanent Canadus desulfation unit attached, but the '13 L3800 has never had anything special done with the battery and is also on its OE battery.
