Airing up a beadlock
Nis
Thread Starter #22
Good on you for asking what to do, if not, your first track day could have ended like the guy in this GTR that thought he destroyed his beadlocks.
LOL, plus I do not understand at a sanctioned drag strip, if it is, dozens of bystanders are in the burnout area.
sc4.6
Port Stanley
Challenger Redeye
It's about as dumb as those street takeovers; those clowns don't realize the dangers until someone gets hit with shrapnel from broken parts, or in the worst case, the whole car.
It's more than a little ironic to see the use of WD-40 and soapy water mentioned when the goal is to keep the tire from moving on the wheel. But at least the soapy water isn't a petroleum product, so the tire doesn't care.
There are products made specifically to lube the tire beads with, and which later (after drying) helps with bead retention, instead of making things slippery.
And it helps a lot to remove the valve core when seating beads, on any kind of wheel.
Soapy water does dry, I used it on mine- a lot of people do
I know that a lot of people do, and that the water dries. The issue is that the soap portion doesn't disappear.
Are you also into jumping off of bridges if others do?
Do you have beadlocks? I have 30+ passes and hundreds of street miles in them, in the wet burnout box. I mark the tire with chalk. Haven’t moved a smidge.
No, I've only tried beadlocks once, and that was to prevent air loss when 'wheeling. Found that it's usually the inner bead that lets go first anyway, so I pursued other ways to be able to run at between 1 and 5 psi.
Regardless, it doesn't make soapy water good for mounting tires. Better than WD-40 obviously, but far from good. Again, there are products made for the purpose.
