2.65 upper with factory lower adding BWoody anti slip...What belt size?
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
As the title says...can anyone chime in?
thanks
Call bwoody and talk to Becca I think she has a belt size chart
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Thank you...I called and spoke to her. She provided a chart that was kind of useless and we were kind of at a guessing point. I went with the Gates K100572HD and it worked just fine. I have driven almost 800 miles so far and no problems.
Regards
Regards
You need to check that it holds under boost of boost fall off at high rpm then the belts slipping and the position of your tensioner will also help you to be able to tell if you need a shorter belt
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Boost is holding up beautifully...I originally had the same belt and after approx 15k miles I started to get belt slippage at 4-4.5k rpm shifts. I purchased the BWoody Anti-Slip idler Pulley V2 off a member here and purchased a brand new belt from Gates. I had my Tech at my dealer install it. We were a bit hesitant but after installing it and he checking the play he said I was good. I havent had any issues so far and holds boost at 17psi.
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Left side approx 15k miles Right side brand new.
I don’t use the green belts
You have the bwoody tensioner
Do you like it
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Looks good
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Do you like it
yeah I do....the I still went smooth and more important it holds boost
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
What kind of boost
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
17psi...I have seen it on a cooler night hit 18
Wow
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
I'm running ID1000 injectors along with colder spark plugs by NGK
E85?
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Thread Starter #18
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Thread Starter #19
93
hellkeezy
hellkeezy
FRAMINGHAM
MA
Charger Hellcat
Thread Starter #20
I hit 18psi one night weather had to be in the 50s...on hot days I'm at 16psi...now with the weather in the 60's I'm seeing 17.
