1320 sway bar part number?
I checked my "As Built" from my 1320 and it has the same code as @DRAGRCR posted above "SDT Drag Mode Suspension". It doesn't give any more detail beyond that, which is weird because it does list the code for the rear stabilizer bar.
Thread Starter #22
found this
List of parts. From a Dealer. Must have a Demon Vin to order.
(2) 4782718AA
(2) 4782722AA
(4) 6101848
(4) 6500399
(1) 68184221AB
(1) 68184226AA
(2) 68217934AA
(2) 68257343AA
(2) 68312673AA
the last numbers on the list 673AA are the bushings so it appears Demon and 1320 use same sway bar
found this
(2) 4782718AA
(2) 4782722AA
(4) 6101848
(4) 6500399
(1) 68184221AB
(1) 68184226AA
(2) 68217934AA
(2) 68257343AA
(2) 68312673AA
Steve White motors was selling the 1320 sway bars and springs as a package to anyone that wanted them. I'm guessing you could call them and get the bar. Or maybe if you tell the dealer you have a 1320, you could get it. There aren't any restrictions on 1320 parts that I'm aware of.
Thread Starter #24
it appears the bar is from a 300 3.6. like I said, they probably found the lightest bar they already made and used it. The bar is available every where.
That’s what I purchased from them and Im using in my car without the front swaybar. The spring rates (front and rear) in the 1320 are identical to the Demon.
Is it different diameter than the standard Hellcat? Curious why the stock hellcat bushings and brackets won't work?
Thread Starter #27
Thread Starter #28
It is different size that is why the bushings are different but it sounds like the brackets work
Thread Starter #29
Bar weighs 7-9 lbs? I'm taking my Hellcat Charger bar off tomorrow to weigh it since it sounds like every bar is different
Thread Starter #30
Well our heavy ass Chargers are not getting the weight from the sway bar. Hellcat Charger sway bar weighs 10 lbs. This is bar only no end links. Good news is I don't have to buy a light weight sway bar, I have one 68184223ab. Can't believe the Challengers are getting an 18 lb sway bar. Maybe mine is hollow and those are solid? hellcat charger bar.jpg .
Interesting. Now I'm gonna have to look at what's on my 2016 Hellcat. Dodge just randomly grabbing parts from the bin again?
My 2009 R/T had completely different seat belt buckles right and left LOL.
Thread Starter #32
From what I read your bar will be different then mine. You should take it off and weigh it
Is this like that trick question that women ask you????
Does this Charger make me butt look big?? :LOL::LOL:
I know my Charger looked way sleeker in the rear than my Challenger did.
He’s talking about checking it on his 2016 HC Challenger. Is the bar the same on a Challenger as a Charger?
Thread Starter #35
I don't think so
Well our heavy ass Chargers are not getting the weight from the sway bar. Hellcat Charger sway bar weighs 10 lbs. This is bar only no end links. Good news is I don't have to buy a light weight sway bar, I have one 68184223ab. Can't believe the Challengers are getting an 18 lb sway bar. Maybe mine is hollow and those are solid? View attachment 20658 .
My 2018 hellcat challenger had a 20lbs solid front swaybar . The rear is solid too but I forget the weight .
Thread Starter #37
2016 Challenger Hellcat front bar 68235661AC weighs 20 lbs bar only. Sure the 2018 bar is same part number
So if you have a Challenger Hellcat you can save some weight
