Standard Body - What are the widest rear tires anyone has run and what did you have to do to the wells, etc...
Thanks for your help. Am already wanting more out back. Stock up front with 20 x 11 305s in back right now.
T_Trahan44
Spokane Valley
2012 Challenger SXT
I vaguely remember a post about fitting 315s on the non-WB charger. But that was as big as anyone was able to go.
IF memory serves correct. And we all know I've a horrible memory.
Slows2k
2018 Challenger
315’s fit with PK designs 20x11’s
Blkout
Warner Robins
345/30/20, 20x12" wheels, Phillips Lil Devil Flares.
20 x 11.5 335s (have to use Phillips Fender Flares though.
315/60-15 M/T Pro. Absolutely the biggest thing you’re going to get in there without ripping out the entire inner fender structure. E89A99F6-6B86-41F3-A177-F085C93A3C6D.jpeg 667E88C0-D6F7-4C69-AB1B-F49273D4E90E.jpeg
NYCSRTATE
NYC
Charger Hellcat
315/35/20 on a 20x11 PK Auto Hellraisers
No rubbing
TMAC
Mesa
2017 Dodge Challenger Hellcat
PK 11" rears and Nitto 315's here as well. Fits perfectly and zero rubbing, even lowered.
This is what I need!! But currently 315/35-20 Nitto NT05R on 10.5 Brass Monkey replicas no rub about flush with the 1/4
Blkout
Warner Robins
Yea, you just can't get anything wider than a 315 Nitto in the back without doing major work inside the fender wells. I'm frustrated that Nitto doesn't make a drag radial wider than a 315. I'd even be happy with a tire compound between the 555R and the G2 for daily driving just need it in a 335 or 345 width.
JRabq
I'd be mindful of tire brand size variability. Continental ECS 305/35/20s on 10.5 PKAD HR5s required plastic liner trimming on my 2017 Challenger. I still use 3mm spacer too since so close even after trimming.
15 HC Charger.
10.5" Factory Reproductions FR70.
Continental DWS06 315/35/20
Ever so slight rubbing of the wheel well liner. Have 8mm spacers & lugs. Need some lug nuts and it's in!
Highly recommend this combo, on a 15+ Charger.
Bob
Riverside, California
Hunter, Blkout - did you guys do work to the inside well like Marc did?
Thanks all for the great GREAT input.
I did not. Got hold of Biz @TRIUMPH
His wheels are amazing.
told him I was using the flares, he set up my wheels.
Have no idea on the offset, you would have to ask him.
But he worked with Bill at Phillips to design a wheel that had no inner issues.
PM me or @Blkout on Phillips.
Blkout
Warner Robins
No work inside the fender well, since the flares give you more width, the wheels have the offset to push them further outside the fenders.
Well, this whole discussion was for naught. Phillips flares don't fit the Charger. Again, we are discriminated against! This is bullshit because I was already picking 345s....
Will check it out, but looks like it may be a one off at this point, or require the whole kit or at least the rocker. Bah hum bug.
Looks like the blue car has a rocker kit.
The black one doesn't.
Keep us posted.
I'll also send an email to Mike Assaf, over there.
Bob
Av8ing1
San Marcos
Says on the bottom of their page "wide fenders are custom installation our service we can provide only in UAE ."
Wonder how it would look with only the rear with flairs...
