It's Axle time. What's the best option here?
Sacramento
Do they come with tone rings??
Not currently, however we do have reluctor tone rings in hand and may be offering as an optional component separately to HellCat nation
BBGSPEED Tech Line
(916) 505-9026🇺🇸
Sacramento
#43
These , they supposedly warranty them for any type of breakage, not like DSS or GForce
Yes, Lifetime Warranty🇺🇸 on CV’s and Axles except on boots! Warranty needs to be done through your selling dealer or BBG direct.
BBGSPEED Tech Line
(916)505-9026🇺🇸
Sacramento
#44
Picked up a vibration during sick summer.. then promptly Chucked the driver's side on the way home during a pull. Outer CV exited the chat in epic fashion. Never found all the internals. Looks like it sheared right off at the base of the cup? Also...diff splines were starting to twist. Days were numbered regardless.
51k miles. 42k modified. Hundreds of hits. It owes me nothing.
Redeye?
DSS?
GForce?
BadBoyz?
Car is not lowered and never will be. I do not autocross. Drag racing and Drag & Drive only. Lots of miles. Lots of launches. Great to absolutely Excellent prep.
F for the stockers. You will be missed. Thank you for your service.
View attachment 183480 View attachment 183481 View attachment 183483 View attachment 183484
Give us an opportunity Sir🔥we’ve captured the attention of some serious builders. We’re not looking to compete, looking to be another solid option for the HellCat Nation!
Made in the USA🇺🇸
BBGSPEED Tech Line
(916)505-9026
What we really need is a good aftermarket tone ring that actually fits all axles as smooth as stock ones do, which can only be had by buying the axles themselves. I've tried two offerings from MPX and TRQ. Both fit horribly. I have 1 from MPX and 1 stock one on.
I'm still running my factory ones on my axles- they work great. i just swap them over with each axle change. id stick with the OEM ones if i were you.
The problem is they get rusty and corrosion in them. I only have the 1, the other was starting to rot
F
Thread Starter #48
Made in the USA🇺🇸
BBGSPEED Tech Line
(916)505-9026
Unfortunately we already have the Redeye stuff at the house. It got delivered while out on Buckeye Skips DnD in Ohio.
Sounds like if we Chuck one of these out...we'll be making a phone call. Or going straight axle. Or lighting the car on fire. Either way. Ha.
Sacramento
#49
Don’t burn 🔥 it down!
