Big day! She hit the ground nearly ready to run.
1. Check and hook the battery back up. Trickle charger said it was too powerful to top off this morning. Fuck it, when it is time I’m hooking it back and firing it up. Lithium is the shit!
2. Prime it turnover once, THEN, start, check oil pressure, double check the level.
Done, ready to rumble!
WTF....seems like all that sun..went to yer brain....yer jumpin then gun...we got a lotta winter left
Speak for yourself, doughnut boi. We haven't got any winter to speak of yet, and I doubt it will arrive before summer gets here.
Got a hardware upgrade scheduled on Tuesday. New left shoulder joint. So I know that until tax day, the limit is 10lb. Already did the right side and needed a matching set.:love: The bench presses were getting a bit off balance.:LOL::love:
So just connecting the battery back up in maybe a few weeks to a month is manageable. Ha, along with driving of course. Hell I remember driving to PT the entire time with the right side busted up and that is when I was driving the shit Chev Tahoe. The Durango will be easy with the correct hand. I remember now, I got real good doing stuff left handed for a while.
Hmmm..."left handed eh"....I'll just leave that one alone:giggle::giggle::giggle:...thank God I still have all my OEM parts intact...and in good working order...Good luck Tuesday bud...(y)(y)(y)
Well spring planting's gonna be a bitch in that dust bowl without H2O :eek::eek::eek:
Easy now...I haven't seen a Donut in 7 months:giggle::giggle:
Just want to be sure I understand, you disconnect the battery during storage?
Yep. The primary reason is to delay or cancel a $1,500 penalty for bricking the DS suspension controller (replacement cost from DSC). So for me it is easier to just disconnect the battery. It is bad enough I need to disconnect the controller each time I change my tune. The lithium feather-light does not seem to lose much if any power if disconnected is a wonderful thing I have confirmed this off season. :LOL:
I have not found a way to tow from under the car w/o damaging the air dam. Ok for strapping to a trailer. Am I missing something?
Chain/cable will barely touch the spoiler if at all
The ovals here visible and then there's another 2 ovals higher up (where chains with J hooks are connected to in this picture)
Also if for whatever reason something has a draw on the system (uconnect) if you disconnect the battery during storage (from my experience) it'll keep most of its charge
Yep, if hooked up, that little car must have a bit and a consistent draw even sitting with no subscriptions or even a NAV option in it.
Disconnecting the battery for an extended period of time is a real PITA come inspection time in NY...car has to be drivin sometimes over an hour..followed by a cool down time..(sometimes overnight) to reboot systems to pass inspection..I much rather leave it connected with a good battery tender than waste 2 days gettin each car inspected
6 years now and haven't unplugged it. Not sure why you bother. Doesn't do anything if you have a tender on it.
Pulled the other axle and diff. Perfect tool for it, don't think it goes high enough for the transmission. Forgot that the diff brace has to come off so the diff can tilt slightly forward for removal. Messed up an MMX tone ring putting it on new axle, have TRQ ones coming in, looks like I'm mix and matching tone rings.
Usually when you're working on your car you pull the negative cable. 9 years of ownership here.
Bowlerguy92
Roads are dry, mid/high 40’s today. Might try and take the cat for a walk.
Good luck and hope for a smooth procedure and recovery
Depends on what you are working on
OK Un Holy Guy....I threw the gauntlet down to Bull and you...let see some "REAL" facial pics of you and Bull.....c'mon dont be a pussy
