Not pretty and not happy. She is going in this week to be returned to the stock springs and its original height, then to get its alignment checked and confirmed on a good machine. Too many clearance problems for the street and potentially driveline components alignment, I cannot get any of my jacks under it without driving it up on some sort of a ramp. Right rear axle will be replaced due to grease seeping, which started after I lowered it. It will be back!
Nice runs. I launch right above idle. I have tried different ways and found it works best for me flashing the convertor
I don't flash the converter at all by foot braking it I just stab it at idle. I'm hoping the 2 step help with reaction time and 60'. It can't be any more tough than just stabbing it from idle. Also have several tunes for track conditions. Cant wait to give it a try, having to pull the supercharger again is annoying though
Are your cars tuned? I'm running the DC Stage 2. I have to foot brake to get the best 60'. Somewhere around 17-1800 appears to be about right.
Heavily tuned and modified. I cut a 1.46 60' by just stabbing the gas
Low 9s
Started off mid 10s stock, upper 9s with pulley and e85 then low 9's with a whipple
Best pass came leaving around 1000 1.33 60 foot
What did I do to it today? Very unusual. Drove in the rain in the Hellcat for the first time in about five years! Had to get it to the damn dealer. Drove in ECO Mode! Wow, if you need to do what I did it became the smoothest and most easy thing to drive than I would have imagined!! It shifted like one of the smoothest luxury cars I have ever driven. Getting the OEM springs back on it today, probably tomorrow or Thursday early I will be assisting with a total alignment to help get the tabs in and out of the AAD arms and connectors. With them running the darn computer etc.
HangZhou
China
If you can, post up a picture of your rotors. And if you have access to a set of calipers and can measure the rotor thickness, that would help as well. They start out at ~34mm thick and the minimum thickness is 32mm.
Maybe it still works?:ROFLMAO:
Self explanatory! Just had the springs returned to OEM and now we are doing a computer confirmation of an alignment. IT WILL BE ON THE NUTS. I’m running the AAD tabs.😍
Rear camber looks off. 0.0 -.50 Don't you want the rear the same?
At that close it did not want to mess with it. I had it on those camber tabs before I lowered it. We just had to do the rear toe, and he made easy work up front on the toe. It took a pair of -1.5mm tabs on the toe arms so that was cool. How do guys set them, exactly the same?
Being the springs were in and out that could have changed it. Going minus 1 (if 5 tab go to 4) on the right side may get you close. I aim for -.25 camber, toe in around .10
