- #1044
- 8,248
- 37,041
- 352
- Riverside
- CA
- 2015 Dodge Charger Hellcat!
Need to get switched power into the engine compartment, or trunk and dont want to run tons of wires to do it?
Well, now you can.
I've put together a completely wireless 2.4Ghz switch package that supports up to four simultaneous zones.
The transmitter sends to a wireless receiver coupled to a 10 amp relay package.
Press your momentary switch once and the relay stays energized until you hit the switch, again. It's pretty slick.
The transmitter is as small as a Saauegia dollar and takes direct 12 volts. Two passive wires are the used to trigger the transmitter, via a momentary switch, of your choice.
The receiver/relay package is housed in a waterproof box, takes 12 volts for power and has two relay leads to work with (COM and NO). This configuration allows you to hook a 12 volt direct source to the COM wire and out to your load (such as an under hood light, smoke screen, oil slick, death ray, etc.), via the NO wire. NOTE: you can hook up any source to the NO wire, or even a data signal source.
Turn time is about 2 weeks, right now... as I am building to suit. If there is demand, I will stock up on parts, to support the community.
Cost: $100, for one single zone package. Free shipping within the CONUS.
Additional zones are +$25.
Let's mod!
Bob
Riverside, California
Well, now you can.
Let's mod!
Bob
1
- Show All
