The Deals Are Starting To Happen
D
Thread Starter #41
That's how the one I looked @ was specked out..not that it matters much now..but how is the mileage on that set up...:unsure:
It depends on how you drive it. Coming home from Jacksonville just now, running 85-100 with a Raptor, it got 16.6.
Combination regular driving it gets about 17.8. Highway staying out of the turbos, it will get around 20+.
That's not bad..better than my over all 3yr. average on my Ram...
D
Thread Starter #43
You can run 87 but it runs really good on 93. Especially with the turbos. It will run almost 20 lbs of boost along with the electric motor.
D
Thread Starter #44
You have to get the dealer to turn off the exhaust sound through the speakers. It sounds ridiculous.
#45
Back in the day...squeezin 20lbs.of boost into a 6cyl.for extended period of time...was a recipe for disaster..the glorious techno age changed that...
D
Thread Starter #46
It's a very controlled boost. It turns on and off as needed, rarely boosting that much. You can watch the guages for it and the motor on the dash.
I was happy with the Laramie trim on the 2 that I had. Neither 1 had air suspension.
Meanwhile my C&C rides quite nicely, even without any load.
And that's obviously with beefy leaf springs in the back and despite a 14,000 GVWR. Bet it could be equipped with a plow, too.
