IC Chiller install & review
U
Thread Starter #242
Hmm idk about that setup. How cold do you get
This setup should be no better or worse temperature wise. It just removes the chiller from the loop when running the factory HX so it's an either or operation.
I've seen mid 30's. I believe that's a function of an improper refrigerant charge though more than the flow loop itself. I know it isn't right since it self-drained at the track last year.
U
Thread Starter #244
I can easily get it down in the low 20s driving around fully up to temp with the drag valve on. I ended up remove my aux tank - I had a leak (custom tank)
catdad
Lake City
Did you make the tank, or buy it? Just curious
U
Thread Starter #246
Bought it but someone had it custom made, used tank is all. Could easily get it repaired, don’t think it’s actually needed - IC coolant temps are 50 degrees max at end of pull
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
I read you guys post every night....I'm wanting to buy the chiller and get the aux. tank with the crash bumper.And I dont want to feel dumb but I'm 68 and this new stuff get the confused. I guess what I'm trying to say do I need to get the 3 way valve? And if I dont get the 3way valve I wont need to put a switch in the car....or am I reading to much into this. I plan on keeping the stock heat exchanger.
rookerrobert
Ridgeland
SC
The drag valve and the 3 way valve are to different things correct? or is the switch inside the car for the darg valve?
catdad
Lake City
Yes 2 different things. Drag valve shuts off cabin ac. 3 way valve bypasses the heat exc. I use the 3 way vale in my system. When its hot in summer time it was taking a while to cool the cabin. I have 2 drag valves on mine, one works with the 3 way valve. If I use the heat exc it will shut off the chiller system. Once my cabin is cold I turn on the chiller and everything works great. Also in the winter time I rarely use the chiller. I over complicated my system but I like my ac ice cold.
rookerrobert
Ridgeland
SC
you and I are different there I dont even use my ac always have windows down just old school I guess.So the drag valve the system is always using the ac for chiller?
rookerrobert
Ridgeland
SC
when I buy the kit I hope it comes with good instructions....lol
catdad
Lake City
IC Chiller is amazing with customer service. You cant go wrong with the kit. The pre made harness was nice. Yes the drag valve is chiller only.
catdad
Lake City
Just a few pics of my install 67425420720__A1A53747-C9F4-42CB-AE18-6E00EB1D1B36.jpg IMG_1212.jpg
Which chiller company has all the problems? Just saw this video...
catdad
Lake City
If you go IC Chiller you are helping the little guy Sumit Goyal and Charlie. The other company is arrogant and takes days to get back to you at times.
rookerrobert
Ridgeland
SC
I like the idea for not having to cut my ac lines. and now the have the crash bumper with the aux. tank. Thats what I'm going with.
U
Thread Starter #258
With IC Chiller, you don’t have to cut suction line. With Forced Induction interchiller (even the p&p kit) you do. I have my stock AC lines and can put the car 100% back to stock if I wanted/needed to
rookerrobert
Ridgeland
SC
thats what I like not having to cut anything....the only thing I dont like is having to put a switch in my car I like to keep mine unchanged. But I'm still going with the ic chiller.I'll just hide the switch the best I can.
U
Thread Starter #260
You can put them inside your center console
