Bead lock wheels do I have to use the bead lock?
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #21
Very good points RGP. I spoke with the techs that are going to install my demon axles and will realign it after the install. They said the same. They also mount bead lock rims. So, I got lucky there. I just need to learn a lot more and be patient.
With any axle, just make sure you don't let it wheel hop. Other wise you will not have any axle issues with the demon axles.
My suggestion which if you are shocking the tires that hard slowing the throttle body from opening will help with that initial blunt. You may even see your 60ft get better from this
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #24
Can you give me directions on how to do that with hp tuners? And values to put? Thanks
I’m still running on stock 2015 axles 😳😳😳 got wheel hop twice last time out for the first time and almost crapped my pants
Are you a gambling man? Because that’s what racing is. Not a matter of if, but when
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Thread Starter #27
Too much of a gambler. :)
