- #1308
- 3,310
- 5,758
- 302
- memphis
- TN
- 2016 challenger hellcat
I HAVE AN 8HP90 HERE THAT HAS MORE THAN THE NORM
A CLUTCH DRUM 7 GPZ WITH UPDATED PRESSURE PLATE NOT THE THIN ALTO THAT STILL HAS A FLEX PROBLEM (6 CLUTCHES IS OEM SET)
B CLUTCH 5 CLUTCH SET WITH PERFORMANCE STEELS UPGRADED FRICTIONS AS WELL (THERE IS NO ADDED FRICTIONS HERE BECAUSE ITS NOT A PROBLEM AREA)
E CLUTCH DRUM 9 CLUTCH SET OEM CLUTCHES (FACTORY IS 7 AND THE USUAL UPGRADED ONES HAVE 8 )
C CLUTCH DRUM 9 CLUTCH SET OEM CLUTCHES (SAME AS ABOVE)
BILLET E DRUM DLC COATED AS WELL(DLC COATING IS NOT OUR NORM BUT ONLY HELPS )
D CLUTCH DRUM 6 CLUTCH SET OEM CLUTCHES WITH UPDATE PRESSURE PLATE (FACTORY D PLATE FLEXES THE SAME AS A PLATE DOES ) HAS PERFORMANCE STEELS
NEW PUMP
UPDATED VALVEBODY
IT WILL BE VERY IMPOPRTANT TO DO ALL THE PROPER INSTALLATION STEPS INCLUDING THE QUICKLEARN !!!!!!)
I HAVE TESTED A SIMULAR SET UP IN MY CAR HERE IN MEMPHIS AND EVEN AJ BERGE WAS IMPRESSED THAT WE RAN FULL 19 DEGREES TIMING THROUGH THE SHIFTS (YOUR TUNING HAS TO BE PROPER ) YOU DONT HAVE TO TURN OFF TORQUE MANAGEMENT TO ACCOMPLISH THIS !!!
YOU MUST HAVE A CORE FOR TRADE AND YOU WILL BE FOR REPONSIBLE FOR SHIPPING
5695.00 YES ITS A ONE OFF UNIT AND ITS AN INCREDIBLE DEAL
NEW PUMP
UPDATED VALVEBODY
- 2
- 1
- Show All
