- #1248
- 49,488
- 159,463
- 402
- Middleville
- MI
- 2016 Charger Hellcat
Had the fall FAST race at 131 Friday. Unlike the spring 2 day event this one is only one day. Start time is suppose to be around 10 but with the cold temps they didn't start to almost 11:30. We would have had -300 da but by 11:30 we were close to 0. I had disconnected my battery to install the BAP a couple of weeks ago so I wanted to program my burnbox back on the buttons and it wasn't working. I found the ground wire had fallen off being it has a spade end when I was attaching the ground for the BAP. Good catch before going to line with no line lock. The battery disconnect would catch me again though
Jon and I lined up for the 1st pass. Something was telling me after the burnout I was forgetting something. Car came out hard 1.35 60 ft but didn't shift to 2nd so fell on it's face as Jon flew down the track to a new best 8.88@155!. The tune is set up when in trans track it leaves in 2nd. Well with the battery disconnected my custom setting in SRT was lost so trans was in street and I didn't check the dash to see it was in 2nd gear. Fixed the setting and went back up and ran 9.32@151 1.40 60 ft. DA was 0. Jon added some more timing on the next pass and went 9.30 @151 1.42 60 ft DA 360. We had a mix of e85 and e85r which is about 95% but was still showing knock. This has been an issue all year and we believe it is false knock so Jon adjusted the knock sensors again
Since the 1st pass leaving in 1st gear the car felt slow leaving in 2nd so Jon said why don't we try another 1st gear launch. We also had an issue we saw 2 weeks ago leaving in 2nd, it gets up to around 3900 rpm and will drop 200 rpm then accelerate again. It has done this every time in 2nd gear so another reason we wanted to leave in 1st to see if it was still there. DA now 525 but I guess the car didn't know that. It hooks in 1st gear 1.33 60 ft and the front lifts a lot and came down different and I think to my self it pulled the wheels off the ground, and it did, both! I knew it was much faster on the bottom and ran 9.12@149. The right lane was showing higher 1/4 mph and the left was higher in the 1/8th. My 1st two passes at 151 were right and the 3rd was left. I always like to run both lanes because of this. 1st gear launch it didn't fall off at 3900 so Jon wanted me to run again with a 2nd gear launch to track some other stuff. Running left lane again pulled a 1.39 60 ft and forth gear hit the rev limit throttle fell for a brief second then took back off. Thought it would be a bad pass but was 9.29@147 DA was 700. I was .04 faster at the 1/8th then my 9.30 pass so if it was a clean pass 9.25. Another guy running a Hellcat right after me went 9.36 and also had something weird in 4th gear where the rpm went up so may have been something in the lane
For our class they pair up cars running close to the same time for a best 2 out of 3. Jon and I didn't go to the drivers meeting being we decided not run anymore but we were the 2 fastest there so it would have been us racing each other. Since they started late eliminations where 2 hours behind and were starting at 4pm. I had made my last pass at 3:30 when the drivers meeting was going to start
This was the last time Jon and I will be running this year. Doesn't look like we will have better DA today or next week and Jon's e85r drum is empty.
It wasn't a perfect day but we ended the season with new bests and had a good time. Race weight was 4690 and if I had the same 400 lbs less to move as Jon did we would have seen an 8 out of my car also
Congrats to Jon on having the fastest pulley only Redeye in the country!
- 4
- 1
- Show All
