Does the cabin air filter clean outside air only?
68coronet
Jacksonville
2020 Dodge Challenger R/T Shaker
What about recirculated cabin air? Is there a filter for this as well, or is only outside into cabin air? Given the VOCs that gas-off the interior, you would think there would be a carbon filter for recirculated cabin air.
The cabin filter sits in the cowl at the base of the windshield, passenger side, which pulls in and filters fresh air only.
Farting less helps the longevity of the filter😁
Based on the location of the filter and where and how it sits, it's only for outside air.
Or at the very least, the freshness of the seat leather.... :unsure:
68coronet
68coronet
Jacksonville
I suppose keeping a window cracked-open will clear it out.
Prange
no longer in Chicago
2021 Charger Scat Pack
Turn on the ventilated seats.🙂
That doesn't matter.....after you force it through the seat foam all of the contaminates are removed and it comes out fresh on the other side :ROFLMAO::ROFLMAO:
Confuzed1
Go Pack Go
Then maybe they should include a "reverse" function on the ventilated seats!!! Max filtering right at the source! :geek:
Matt someone with an SRT
Newtown
Yes you got your heated seats, ventilated seats, and auto fart fan relief.. all standard equipment on the 2022s 😂
Beeing in the air cleaning business fer years,,, do not receive a blow job from a gal that blows any faster than a sneeze exhaust from a mouth you wood not take home to your cousin. Or, if from Kentucky, a gal that cost less than $15. From Mi, that wood be a gal that has less teeth than yo 2nd grade teacher. If you made it that far before loosing you'll nose to a fart blown to you from your sisters 3rd grade 4th cousin. Speakin of sneezes, the average one can have an estimated travel velocity of 200 mph at exiting a mouth with all 32 each teeth in er mouth. A cabin air filter is nothing moe than a piece of card board wit tissue stretched over it with out the HEPA bungy cord. If you are like my germ forbiden fobic ass. You will install a UV 25 watt germ killing single or double tube light. They do not draw much amperage, so no worry about that piece of shit batry you have in the trunk, snot hood. You can teach yo sister how to blow a germ free sweet smellin exhaust breath towards a livin demon free soul. The less than efficient 7 layer HEPA and or charcoal filters do no good except take you'll hard earned cash, you could spend on 2 blue pills or a betta rad it eator. Less weight fer aluminum. Placining you all beautiful's gal friends ass in a car seat fer 10 hrs with dirty air will do her COPD no good. Fer moe info, inbox me.
Hickster rama
