Best recommendation for fixing hairline cracks
Hemidayz
Las Vegas
NV
2020 WB Hellcat Charger
I found this hairline crack on my trunk, what is the best course of action to fixing something like this? Would bondo bumper repair with light sanding and some touchup paint do the trick? I've only had the car for a month, i'm not sure what the dealership can do for me, even it is there fault.
Clear Gorilla glue with something to hold the parts together while it sets. Prob. woun't even need touch up after.
Hemidayz
Hemidayz
Las Vegas
NV
Only problem there is no area to hold the two ends together
Not sure exactly where that is on the car from the pic, but there has to be some way to rig up a ratchet clamp or strap (and towels as a buffer) to apply pressure while it dries.
Stop drill before anything, or crack will continue.
The extent of my knowledge.
Edit:
Take it to dealership.
Hemidayz
Hemidayz
Las Vegas
NV
Edit:
Would warranty cover this? It’s only been a month since I’ve had the car now.
It better.
2021 Jeep GC 5.7 TrailHawk
Your 3/36 Warranty is a bumper to bumper warranty. It covers everything including paint problems and any other quality control issues interior or exterior. Don’t try to fix it yourself or it won’t be covered...
Dealer should remove, replace and repaint the entire rear fascia.
Either way, just make sure they remove it before repairing and/or repainting anything.
Hemidayz
Hemidayz
Las Vegas
NV
The dealership told me that the crack could be from possible damage done by myself so it may not be covered. also one side of the front bumper isn't clipped in all the way and the same guy was telling me i could've done it when I backed out of a steep driveway.
Toupee
Just deny it. That would not get cracked or come unclipped without a huge scuff on your bumper. They should replace the bumper cover. You can’t fix the crack without it showing.
Hemidayz
Hemidayz
Las Vegas
NV
How could I have damaged that? closed the trunk to hard???
2fast4u
Edwardsburg
No way...Tell the dealer you treat it like a baby and want it fixed.If they refuse, get on here and send message to @DodgeCares and hopefully they can help.
Deano
Law Enforcement
Roy
2019 Challenger WBHC
Just in case a dealer will not make it right, like Hunter said, drill a very small hole at the end of the crack to stop it from spreading.
OOps. New car or new dealer. Take your pick?? Not like the picky dealer. Mine wood love to chare it out to the factory.
Want cover the cover plate crack ster. AAA
Piening2150
Toledo
2017 Charger Daytona 392
I'd already be headed to a different dealer then (if that's an option). Unacceptable.
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
You would think that the dealer is paying for the repair out of their own pocket! Dodge needs to crack down on these bullshit claim denials. You can look at a problem and tell wither it is customer damage or not. Maybe a damn gremlin took a pick axe and pecked at it till it cracked! useless B-tards. I wont ever buy one of their cars again. And it's all because of customer service. You hear that Dodge Cares? It would be nice if it did care!
