Spinning wheels inside tires
HRJ
Porsche GT3
Those of you with DRs on the factory wheel, have you been able to solve the issue of spinning the wheels inside the tires? Other than buying a beadlock? lol
2fast4u
Edwardsburg
I had my Nitto's installed at Belle Tire, they used a "permatex" looking adhesive when mounting...tires moved about 1/2" after 1st launch, and haven't moved since
sad
Bartlesville
OK
knurled beads on the wheels will help a lot.
TNREDEYE
Shelbyville
2021 Super Stock
I have a WBRE w the stock Devils rims. They are factory knurled. I'm running the Nitto nt05r 315/35/20 on them currently. They're not glued on or any such thing. I've made maybe 15 runs at the dragstrip w them and they've moved around 1 1/2". They seem to move pretty much every run I make, so I don't see them settling in any time soon.
I now have some aftermarket whls w the 315/50/17 MT EtR. They are also non beadlock.. and I think it's fair for me to expect them to move as much or more than the stock whl setup does.
From all I've spoken to it just comes w the territory if you run non beadlocks on an over 2 ton car that runs good.
2fast4u
Edwardsburg
That is the very reason I had them "Glue" the tire to the bead, I also have factory knurl in devil's rims...gluing stopped it from spinning after 1st launch. Must say, I was pleasantly surprised, same exact tire combo 315/35/20 NT05R.
