- Member ID
- #1044
- Messages
- 7,241
- Reactions
- 33,463
- Likes
- 352
- City
- Riverside
- State
- CA
- Country
- United States
- Vehicle
- 2015 Dodge Charger Hellcat!
This is an issue that I dealt with on my 2006 SRT Charger. Seems like they are still using the same junk materials.
Issue: Radiator cap (coolant overflow tank cap) failure. The rubber gasket, in the cap, cracks and pisses out fluid.
Symptoms: Light odor of coolant. Higher operating temps, than normal.
My Cat has 90k on it and is DD. Your mileage may vary.
Quick visual inspection, when engine is COLD, should do the trick, if you want to verify condition.
As a side note, I checked the I.C. tank cap and it was good.
Here are a few pix, so you know what to look for:
Hope this helps.
Hope this helps.
5
3
3
1
- Show All
