OST Dyno - Unlocked PCM's with Preloaded Custom Tune
ostmike
6 Second Best E/T
Portersville
2015 Hellcat
Do you want to simplify your performance modification/upgrade process? We are providing an option to make it even easier!
Are you uncomfortable with loading tunes or datalogging?
Although you will eventually need to become familiar with using a computer we can get you up and running without the need to understand this process immediately.
This offering is designed for the DIY individual or shop that can make the mechanical modifications but are unfamiliar with tuning this platform.
We have been using this process in the shop as well as offering it to remote customers and shops with great results. To utilize this offering you will need to purchase a remote tune from us as well as an unlocked PCM.
This option will allow you to make the upgrades to your vehicle (injectors, pulleys, cam etc.) and simply plug the OST Dyno PCM in and go.
Having completed several hundred of these tunes both locally and remotely since 2015 there is very little fine tuning needed.
When using this process in the shop, the preloaded PCM is installed in the vehicle, the cars start and run like stock, Micah straps it to the dyno and the majority of the time there are few if any changes to the tune required.
To utilize this offering you will need to purchase a remote tune from us as well as an unlocked PCM: https://shop.ostdyno.com/shop/hellcat-demon-trackhawk/
Here is the link for the "Preloaded Custom Tune" option. After purchasing the PCM and Remote Tune just add this to your cart with the appropriate choice (See option on the page this link directs you to): https://shop.ostdyno.com/shop/shop/...tuning/unlocked-pcm-w-pre-loaded-custom-tune/
StingrayZ51
Lindenhurst
Mike would there be any point in just getting a tune without doing anything else such as a pulley swap? I would be interested in an unlocked tuned ECU with a tune that would be just plug and play on an otherwise stock wide body Hellcat. Thanks.
ostmike
ostmike
6 Second Best E/T
Portersville
2015 Hellcat
Absolutely! Especially if you combine a race fuel tune with a TCM tune. As long as you have sticky tires you will see a 60' and ET gain.
Reach out to Speedy. I believe he has this exact scenario well documented when we tuned his Hellcat in stock form.
Interesting. I didn't realize Speedy got a tune before the pulley swap.
I have been thinking about doing the same as StingrayZ51
StingrayZ51
Lindenhurst
I don’t track the car but would love some more power. I’m just not sure I want to do the injectors, pulley and tune yet. I did a tune and headers on my C7 and it really woke the car up. And being able to put the stock computer back in is appealing. Mike could you PM a price please.
ostmike
ostmike
6 Second Best E/T
Portersville
2015 Hellcat
For pricing please go to our website, add the components you need (there are several options even for a stock vehicle) and the total will be displayed in your cart.
You will need to add the unlocked PCM, a remote tune (with or without TCM tuning), then select the "Preloaded Tune" option and choose the tuning module option you prefer.
Latest Forum Posts
