incognito pulley and 2.75 upper?
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
I'm kinda wondering if I was to install the incognito pulley and have it rtuned would that be to much boost for stock engine? I have 1050X injectors and dual 525 pump but I'm already running a 2.75 upper so with that being said I'm running about 15lbc. boost. I know that the incognito pulley will add about 1.5 to 2lbs. more is that to much? Is anyone on here running that set up?
Jon-MooredPerformanceLLC
Martin
2018 Dodge Challenger Hellcat
Typically, the 2.75 upper is going to be absolute max for pump gas. I would not recommend anything more.
At least if I remember right you are on pump 93.
rookerrobert
rookerrobert
Ridgeland
SC
yes your correct....pump gas only 93
