DA was 5400 and I did a k
I have a great new tuner! I will keep that confidential at this time. So I ran with farm truck and arm. Got my younger 15.5 yr old daughter a slug bug shirt which they both signed. Now the run that got me kicked out.
1). At 5400 feet I ran 9.71 at 142. There was no other car or truck as fast as me. There was a towed ninja bike which ran 9.71 at 138.
I got a 1.35 sixty foot.
2). My tuner read some logs. With a 10 percent lower and 2.5 upper I was only making 14 psi. The sc is original and probably worn out. He said the kpa was only 200 whatever that means.
3). So he is having me add one degree of timing. But I am going on vacation and can’t log for him for two weeks.
I think I may keep it Mopar and go with a 2.7 and a ported top.
I am sure I could of done a 9.6 as when I ran at 5 it was 83 and it cooled down to the high 60s. Just weird only 14 psi.
Show me a slip and I'll give you your 9sec banner.
It is attached. :)
Done!
Local tuner or bigger name? Jon data logged my stock car last weekend and I thought he said he saw 11.8. DA was around 0. Now keep in mind, with higher DA you loose boost being there isn't as much air to compress
Also the bigger cube engine is going to flow more air which will make the boost drop. Boost is back pressure so for instance if you put a 2" exhaust on your car boost numbers would go up but it also would probably be slower
Why I told Bull to go with smaller pullies being the altitude
And Congrats on the run!
Sometimes in the summer I see da s of 7000 feet. Tracks is at 3100 feet. Temp. was 83 with 20 percent humidity and 29.9 pressure. Yes 7.0 liters with a ported snout, 2 inch headers and 3 inch exhaust. Plus the higher da.
Congrats @AlleyCat , that's fast no matter what the DA !
Damn good for a VW. In reverse.
My youngest daughter, 15.5 yrs. old had taken this. Not too good. But she was a sweetie even wanting to go with Dad to the track. My older one, 17.5 yrs. old will not even consider going.
