2019 Challenger Hellcat Redeye magnetic plugs
Some of you old timers may recall Dimple had a complete kit for our Hellcat’s back in the day.
Any body know of a kit for 2019? If not a kit what are the sizes?
Thx all.
Octanewide
House of power
Thx all.
These are on my 18 Hellcat..
Oil pan M14x1.50x16
Oil cooler M12x1.75x21
Asheboro
NC
2019 WBHCRE
This is why I love this board.
Thank you and I never asked the question.
L J
Oil pan M14x1.50x16
Thanks.
https://goldplug.com/
Not cheap...but have one on the F550 and Durango. Good quality...next will be Hellcat.
Oil pan M14x1.50x16
Awesome. Any one got any ideas on the rear end?
Are they as magnetic as these? These attract particles from 1/2 ft away!! If you have a Manual transmission you won’t believe what they pull out of the lubricant!!
so if you use one of these and go to change your oil and its looks like a porcupine
would that mean its turned into a porche because I heard the only difference between a porcupine and a porche was the pricks are on the inside
Funny thing the first time I installed one in an older transmission when I removed it it did look like a porcupine I was shocked and thought my tranny was f’d. So I got a white paper towel to wipe it off with so I could start picking the pieces out to see what they where and they magically all disappeared into the paper towel like a slime. Here it wasn't big pieces just trillions of microscopic sub micron grit that where in suspension in the magnets magnetic field. Cleaned the plugs ( one in the drain one in the full catching oil as it’s coming off the gears) and next oil change they only had 1/4 of the debris of the first time, they cleaned up any and all ferrous grit that even oil changes don’t take with them. I have them in every vehicle I own (including my quads and lawn mowers even) in every plug that sees oil, trannys, transfer cases, auto transmissions, everything. Next time I find one that looks like a porcupine I’ll take a picture of it, simply amazing.
PM Jettster on the other board, he sells them under the table so to speak.
Thanks
HarleyHetz
ARLINGTON
Subbed
PS, the super plugs in video aren’t purchased plugs, I make them from high temp high field strength neodymium magnets. Most have a 30-35 lb pull strength, I don’t think any one sells plugs with this string of magnets in them.
Well...someone should.
Go Goody
Stuart
16 Hellcat Challenger
48 bucks for 2 plugs (oil cooler and pan plug) and 10 washers....ooof
Make your own better ones for 20
Columbiana
I just purchased Dimple plugs from Richard. Supper strong magnets. Checked them out! https://drainplugmagnets.com/
