UPDATE! "Water Spots" - What is the best way to remove that is not abrasive?
Pulled this thread up;)
My dad has well water and I had a black truck years ago that would get water spots from the sprinklers. I tried different things to get them out little did it help. There was one thing that worked very well.....rain! If we had a good rain they would disappear
Thread Starter #42
UPDATE:
As I mentioned in the What Did You Do With Your Hellcat Today thread, I finally got the spots out.
Maguires iron remover, Chem Guys Water Spot Remover, clay bar.
I did not use the clay on the glass so there is still some spots visible. Next wash I'll clay the glass.
A lot of effort but it worked without buffing. Very happy! :D
Thread Starter #43
Holy wood stack Batman.
Fwiw, a friend of mine is a professional detailer. He recommends a 50/50 mix of water and vinegar to remove water spots. Obviously clean the area first, wipe with solution until spots are gone, then a fresh coating of sealant. I've used this technique a couple times with great results, the water spots come off pretty easy too.
Also just fwiw...this sealant is really good:
https://www.amazon.com/CARPRO-Reloa...prefix=reload+car+sealant,aps,176&sr=8-2&th=1
Thread Starter #46
I tried the vinegar, mix, full strength, did nothing. It sure felt like the iron remover and water spot remover were very acidic. Then a quick light clay finished what remained. I did not expect it to work as well as it did. After, I put on Grotts "ceramic" wax.
For the next 2 days, I had water beading up and rolling off my hands! (I did not wear gloves for any of it.) I think I will when I do the 170 next time we the right weather.
Thread Starter #47
What you see it next years indoor stack, the empty space next to it is this years. Then there is the wood in remote shed which holds about 1.5x the indoor.
Hey, winters here in NH are long and hard like..... The trees...
