Sad Sad Day my SUPER STOCK IS DOA
Illegal_Demon
Open Space
spun bearing but want to keep numbers matching?
Pull the motor and have it rebuilt.
Dodge will gladly do the repair for you. BUT if you need it to be the way it was from the factory, you will probably have to pay out of pocket for it.
Or order a new one and get rid of this one?
why would dodge charge you to fix it (cheaper) but not charge you for a full service replacement block (more expensive)? My bet is they would rather do the cheaper of two options. if they replaced the spun bearing how would that "not be as it was from the factory". Its still a dodge part and internal. bigger deal long term is the numbers matching block imo, which would be preserved.
They don’t want their monkeys inside a motor…
Warranted motors..and transmissions...pull and replace..more often than not...
Illegal_Demon
Open Space
#44
Wow, I get it but that's sad. So much for "certified SRT technicians". Guess they can concentrate on changing the oil, lol
#45
They pull and replace the block etc. in a few days - done and done right. The best consistency in manufacturing and building is coming out of that factory in Mexico. And, I mean that as a positive comment about Saltillo. I don’t want any misunderstandings or other assumptions from my post.
Looks like a few have answered this question
But its not as simple as replacing a brake rotor/pads or transmission flush.
This will require pulling the motor, full disassembly (because its the crank shaft), and rebuild. Shit has to be just right/balanced etc.
I wouldn't want a Dodge dealership doing that work.
So if the OP wants to keep it numbers matching, he will have to pay out of pocket for an engine shop to rebuild the motor (and maybe go up some cubic inches).
Plus its just cheaper to swap out with an engine Dodge has sitting in inventory and they will refurbish it etc on their end.
#47
Once SRT approved, my car as delivered back in four working days, complete new heart, lungs and fart tubes, with replaced cooling systems. They had the parts and pieces delivered in two days!
Well said and explained @Boris.
To be fair, a dealership service bay is not equipped for a proper rebuild. They’d have to send it off to a machine shop for a ton of the work, and still count on their guys for final assembly… too much of a gamble.
cole3986
Lawrenceville
#49
Good technical here, at the end of the day let Dodge take care of it, IMO. Always done me right, as I said before, shit happens
I wish I was as lucky. Been waiting since April 14th. Took 3.5 weeks to get an ok from FCA for a new heart. Still waiting.💩
I even offered to pay the difference to get a RE motor. Of course that doesn't compute.
#51
That bites. What are they saying is the hold up?
Engine is back order. Delivery was to be June 14th then the week later and then end of June. So really no clue.
I offered to pay the difference for a RE long block but of course the PN# doesn't correlate so that isn't possible so far.
U
UNDER PRESSURE
San Tan Valley
2021 DODGE CHALLENGER REDEYE SUPER STOCK
Thread Starter #53
Got the update on Friday that Dodge requested more teardown for the replacement. They removed the oil pan and found a grip of metal in the pan, oil filter and that a few of the cylinders were scorned pretty badly. The heavy tech working on the car thinks that the bearings used were the wrong size and that it would not have been noticed until the car heated up and things started to swell. I could be waiting for 1-2 months for a motor once approved since all of the H/C R/E motors are on restriction. The only real good info I received was the fact that the motor will be assigned to the VIN. Good info thanks DGatzby.
Illegal_Demon
Open Space
#54
so remains numbers matching? wow wish they did that in 60s, lol
Boy that 1 to 2 month delay would really be problematic if say you lived in the North East...and didn't drive it for the winter...sadly ..have no idea on what if any compensation would be in order...man that really sucks...
That's a good point. Don't mean to rub salt in the wound @UNDER PRESSURE but this is one of the badder horror type F'u^&ed Up stories I've heard about. I mean this is basically a brand new, flag ship, super star, super car, high priced vehicle made by the company. And it basically comes with a blown motor(ie. ruined) out of the gate. Soooo what's his compensation for being without the car for however long it takes? And his aggravation?. Is it monetary? OR do they owe him a car of "equal or greater" value to use while he waits for his to be done? At least they should have to do the latter. At least.
Illegal_Demon
Open Space
#57
I agree. How about buy the car back at what I paid and lets start from scratch...new order new car, new motor, etc...after all with used car prices sky high the dealer can do fine..and if not, write the loss off. better than royally screwing the customer which is whats happening here...
#58
No such thing as numbers matching like vin stamped on block anymore. Just a bar code decal.
I'd definitely ask for some concessions. My 2016 Camaro 2SS had some funky torque converter problem that took 2 months to get parts for. I called Chevy and told them I didn't want the car and to buy it back. They offered me a 5 year b2b warranty as an option so I accepted. Never planned to mod the car and added a bit of value when I sold it. You can ask for the payments be reimbursed and stuff like that since you don't have use of the vehicle.
Confuzed1
Go Pack Go
#59
-Makes me wonder if they are actually putting these engines on a dyno for 42 minutes like they used to claim.....
#60
Mine seemed too easy. They should be doing the same for everyone. Ship in the long block and add a new SC and any other busted or defective items, remove and replace; done.
